Bricscad Crashes at startup
Mandriva Linux release 2010.0 (Official) for x86_64
BricscadClassic-V11.1.17-1-en_US.rpm*
Bricscad is crashing at startup. Up until now it has worked well. Not sure what is causing this. Any ideas how to diagnose the problem ?
The program 'bricscad' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadRequest (invalid request code or no such operation)'.
(Details: serial 15208 error_code 1 request_code 136 minor_code 19)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
This issue is solved. Using the below link I was able to upgrade to the latest fglrx driver. Bricscad is back up again.
http://wiki.mandriva.com/en/Updating_proprietary_drivers_from_backports
