CPU specs.
I'm having to order a new desktop system and was wondering if a Intel i5 2.8 GHz. was enough cpu muscle for 3D work (no 10,000 part assemblies). If not I'll have to go for broke and get a i7 and pay the premium.
For day to day work I think you will find an i5 more than adequate. I can't remember the details, but most i5 and i3 have built in graphics. These may present an issue if you plan to upgrade to a stand alone graphics card later, as this could result in slower graphics than the internal one. Bricscad is currently 32bit, so not a lot of advantage in having more than 3GB of ram or running 64bit windows.
According to ther Knowledge Base running V11 on 64 bit Windows the memory limit for drawings is 4GB.
Yes your right. details below.
INCREASED MEMORY LIMIT: until V10 the limit of the amount of memory that could be used by Bricscad was around 1.6 GB. In V11 this limit has been increased to 4 GB on 64 bit systems and 3 GB on 32 bit systems. On 32 bit systems additional manual changes to the boot process are required.
- 32 bit XP: set /3GB flag in boot.ini. It is recommended to back up your boot.ini beforehand.
- 32 bit Vista/Windows7: on windows commandline run 'bcdedit /set increaseuserva nnnn', nnnn being a number between 2048 and 3072. The default value is 2048, to allow for 3 GB set it to 3072.
That said, however I would think most people wouldn't need this day to day. One of the nice things about Bricscad is it runs happily on low spec machines. The high school I run training courses out of uses Asus eee PCs, which aren't that powerful, but Bricscad runs fine.
