autoloading BRX at startup
Hi there,
I'm using Bricscad V11. I want to have DOSLib commands available each time I start Bricscad. I put it in the appload list and have "save updates" box checked.
Bricscad remembers it in the list but does not load it. Am I not understanding something here?
Thank you in advance for your help.
Phillip
  • Hi, Phillip.
    the APPLOAD dialog only lists a kind of "history" - those files are not loaded at startup.
    2 possible solutions :
    1. use a standard Lisp file (on_start.lsp, on_doc_load.lsp) and add (arxload "doslib11.brx") there;
        you can also place that Lisp statement into a MenuLisp (*.mnl) file
    2. you can also use "autoload.rx" file, and add the filename there (doslib11.brx)
        that file is also processed at Bricscad start
    I hope this helps ?
    Many greetings, Torsten
  • Thank you Torsten for your timely and helpful reply.
    Phillip
