Hello Guys,
As you know there are two styles in drawing in Bricscad i.e. Standard and Isometric. I am working in Isometric style for creating isometric drawings by changing the style i.e
command: Snap -> Style -> Isometric
When i am drawing in isomteric while changing the plane i.e. either Left/Right/Top the rubber banding does not change as the plane changes, which means if i have to draw the object by changing the plane i need to cancel the command and change the plane first then start drawing this is a time consuming task, and this works fine in AutoCAD so can you guys tell me some solution to this, do i have to set some system variable to get it right.
Thanks in advance guys
Sanjay.
Your right. CTRL E toggles the plane, but the ortho stays with the plane you started in. I suggest you raise a support request.
