Repeat command problem
Lately I've had a problem with a certain command repeating (via right clik or enter) eventhough it wasn't the last command called. Sent a support request and they asked I do this:
The list of loaded applications can be obtained with lisp (arx) call; could you please give the result of this function?
Can anyone tell me how to this in "layman's terms"???
It seems listing out the command history ought to be enough to determine if there's a third party app involved...
In Bricscad type in (arx) at the command line. This will run the arx lisp function which will list all the drx applications loaded. I get the result below when I do it in Bricscad.
: (arx)
("plotstyleservices_2.06_8.drx" "dd_dynblocks_2.06_8.drx")Copy the resulting output from the text window into your support request.
