Civilcad 2010 problem
I want to try Civilcad 2010.
If I got contours from an outside source in dwg format, how can I use them for designs?
I've also got a list with approx. 1500 points. After opening it using CC2010 and pressing the refresh button, CC only goes up to 88% after a while...nothing more.
A dialogue box appears that says the following: "CivilCAD is in the middle of AutoCAD command. Complete your command/Cancel it before taking any action."
What causes this problem? How can it be fixed? And how can I affectively test CivilCAD?
Thanks
  • Hi DJ,
    Civil Cad 2010 is listed as a third party application from Sivan Design of Israel. I think you must contact them to get support of how to use Civil CAD. This forum is for core Bricscad related stuff.
    This is their address:
    Sivan Design
    17 Hatidhar St.
    Raanana Merkaz 3019
    ISRAEL
    http://www.sivandesign.com/
    +972-9-7427991
    Regards
    Rakesh Rao
    http://rakeshrao.typepad.com
