TCOUNT command
Greetings
always I am bothering again with my questions, Sorry ![]()
I want to know if exist some command as the TCOUNT of express tools in Autocad, this command can take texts and to put sufix and prefix, and to do increments. Example: if you have various texts with "Bedroom" you select all te texts with the word bedroom and you will have Bedroom 1, Bedroom 2, Bedroom 3, etc easy. and the functions of prefix and sufix is usefull too.
I dont know if exist something similar in bricscad, but I found a lisp routine in the web that can resolve my problem, but it has a little failure, I cant do a window selection, I should pick one by one any text, ....so sad. Perhaps somebody could add the option of window selection, I cant do it... ![]()
I repeat, I found this routine in inernet, I hope dont break any rule of copyright with this.
thanks a lot
;; Increment Text lisp routine
;; by: Irné Barnard
;; Read from registry is exists
(if (setq INCRset (getenv "IncrementSetting"))
(setq INCRset (read INCRset))
(setq INCRset '(1 "" "" 1 1 t))
(setq alphalst '("A" "B" "C" "D" "E" "F" "G" "H" "J" "K" "L" "M" "N" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z"))
;; Utility function to convert alpha number to integer
;|(defun alphatoi (a / i neg n)
(if (setq neg (= "-" (substr a 1 1)))
(setq a (substr a 2))
(setq i a n (strlen i) a "")
(while (> n 0)
(setq a (strcat a (substr i n 1)) n (1- n))
(setq i 0 n 1)
(while (<= n (strlen a))
(if (= n (strlen a))
(setq i (+ i (* (vl-position (1- n) )
(setq n (1+ n))
(if neg (setq i (* i -1)))
i
;; Utility function to convert integer to Alpha number
(defun itoalpha (i / a neg)
(setq neg (< i 0)
i (abs (fix i))
a ""
) ;_ end of setq
(while (>= i 0)
(setq a (strcat (nth (rem i (length alphalst)) alphalst) a))
(setq i (- i (rem i (length alphalst))))
(setq i (fix (/ i (length alphalst))))
(if (= i 0)
(setq i -1)
(if (/= (rem i) 0)
(setq i (1- i))
) ;_ end of if
) ;_ end of if
) ;_ end of while
(if neg
(setq a (strcat "-" a))
) ;_ end of if
a
) ;_ end of defun
;; Command to increment text values by picking
(defun c:Increment (/ dcl_id obj objid id fin rate start value prfx sufx digits numerals paused)
(setq start (nth 0 INCRset)
prfx (nth 1 INCRset)
sufx (nth 2 INCRset)
rate (nth 3 INCRset)
digits (nth 4 INCRset)
numerals (nth 5 INCRset)
) ;_ end of setq
(defun Setup ()
;; (setq DCL_ID (load_dialog "Increment.DCL")) ;Removed for 1.3
(setq DCL_ID (load_dialog_Increment)) ;Added for 1.3
(if (not (new_dialog "increment" DCL_ID))
(exit)
) ;_ end of if
(defun CHECKOUT ()
(setq start (atoi (get_tile "start")))
(setq prfx (get_tile "prefix")
sufx (get_tile "sufix")
) ;_ end of setq
(setq rate (if (= (atoi (get_tile "one")) 1)
"1"
(if (= (atoi (get_tile "two")) 1)
"2"
"0"
) ;_ end of if
) ;_ end of if
) ;_ end of setq
(setq rate (atoi (if (/= (atoi (get_tile "increase")) 1)
(strcat "-" rate)
rate
) ;_ end of if
) ;_ end of atoi
) ;_ end of setq
(setq digits (atoi (get_tile "digits")))
(setq numerals (= (get_tile "num") "1"))
(setq INCRset (list start prfx sufx rate digits numerals))
(setenv "IncrementSetting" (vl-prin1-to-string INCRset)) ;Save to registry
) ;_ end of defun
(defun DONE ()
(setq fin 1)
) ;_ end of defun
(if (/= start nil)
(set_tile "start" (itoa start))
) ;_ end of if
(if (/= prfx nil)
(set_tile "prefix" prfx)
) ;_ end of if
(if (/= sufx nil)
(set_tile "sufix" sufx)
) ;_ end of if
(if (/= digits nil)
(set_tile "digits" (itoa digits))
) ;_ end of if
(if numerals
(set_tile "num" "1")
(set_tile "alpha" "1")
) ;_ end of if
(if (/= rate nil)
(progn
(cond
((= rate 0) (set_tile "none" "1"))
((= rate 2) (set_tile "two" "1"))
((= rate -2) (set_tile "two" "1") (set_tile "decrease" "1"))
((= rate -1) (set_tile "decrease" "1"))
) ;_ end of cond
) ;_ end of progn
) ;_ end of if
(action_tile "accept" "(CHECKOUT)(done_dialog)")
(action_tile "cancel" "(DONE)(done_dialog)")
(start_dialog)
(unload_dialog DCL_ID)
) ;_ end of defun
;; Don't show settings dialog at start. Show settings on command-line instead
;; (SETUP)
(while (/= fin 1)
(while (and (/= fin 1) (not (or (= id "Pause") (= id "TEXT") (= id "MTEXT") (= id "ATTRIB"))))
(setq obj nil)
(if numerals
(progn
(setq value (itoa start))
(while (< (strlen value) digits) (setq value (strcat "0" value)))
) ;_ end of progn
(progn
(setq value (itoalpha start))
(while (< (strlen value) digits) (setq value (strcat "*" value)))
) ;_ end of progn
) ;_ end of if
(while (and (/= fin 1) (= obj nil))
(setvar "errno" 0)
;; Show settings on command-line instead
(princ "\nStart=") (princ start)
(princ "\tPrefix=") (princ prfx)
(princ "\tSuffix=") (princ sufx)
(princ "\tRate=") (princ rate)
(princ "\tDigits=") (princ digits)
(princ "\tNumerals=") (princ numerals)
(if paused ;Added pausing increments
(princ (strcat "\nIncrements are Paused, current value=" value))
(princ (strcat "\nWill increment to next value=" value))
(initget 4 "Pause Change") ;Added pausing increments
(setq obj (nentsel (strcat "\nSelect text...(" value ")[Change/Pause]")))
(cond
((= (getvar "errno") 52)
(setq fin 1
obj 1
) ;_ end of setq
((= obj "Change") (Setup) (setq obj nil))
((= obj "Pause") ;Added pausing increments
(setq paused (not paused))
(setq id "Pause")
((/= obj nil) (setq objid (entget (car obj))) (setq id (cdr (assoc 0 objid))))
) ;_ end of cond
) ;_ end of while
) ;_ end of while
(if (/= fin 1)
(progn
;(setq objid (subst (cons 1 (strcat prfx value sufx)) (assoc 1 objid) objid))
;(entmod (list (assoc -1 objid) (cons 1 (strcat prfx value sufx))))
;; Version 1.3 changed to use ActiveX
(if (/= id "Pause")
(progn
(vla-put-TextString (vlax-ename->vla-object (car obj)) (strcat prfx value sufx))
(command "_updatefield" (car obj) "")
(entupd (car obj))
;; Added pausing increments
(if (not paused) (setq start (+ start rate)))
(setq id nil)
(setq obj nil)
) ;_ end of progn
) ;_ end of if
) ;_ end of while
(princ)
) ;_ end of defun
;;; Function to load Increment dialog
;;; Added at revision 1.3
(defun load_dialog_Increment (/ fn f)
(setq fn (strcat (getvar "TEMPPREFIX") "Increment.DCL"))
(setq f (open fn "w"))
(write-line "//" f)
(write-line "// Increment text Dialog Box definition" f)
(write-line "//" f)
(write-line "// by: Irné Barnard" f)
(write-line "// Version 1.2" f)
(write-line "// " f)
(write-line "// Version history" f)
(write-line "// ==================================" f)
(write-line "// 1.2" f)
(write-line "// Added alphabetic increments" f)
(write-line "//" f)
(write-line "// 1.1" f)
(write-line "// Add prefix / suffix" f)
(write-line "// Add minimum digits" f)
(write-line "//" f)
(write-line "// 1.0" f)
(write-line "// Initial version" f)
(write-line "//" f)
(write-line "increment : dialog {" f)
(write-line " label = \"Increment Parameters\";" f)
(write-line " initial_focus = \"start\";" f)
(write-line " : column {" f)
(write-line " : row { : edit_box {" f)
(write-line " label = \"Starting Number:\";" f)
(write-line " value = \"1\";" f)
(write-line " key = \"start\";" f)
(write-line " }" f)
(write-line " : edit_box {" f)
(write-line " label = \"Min. Digits:\";" f)
(write-line " key = \"digits\";" f)
(write-line " }}" f)
(write-line " label = \"Prefix:\";" f)
(write-line " value = \"\";" f)
(write-line " key = \"prefix\";" f)
(write-line " }" f)
(write-line " label = \"Sufix:\";" f)
(write-line " key = \"sufix\";" f)
(write-line " :row {" f)
(write-line " : boxed_radio_column {" f)
(write-line " label = \"Direction\";" f)
(write-line " : radio_button {" f)
(write-line " label = \"Increase\";" f)
(write-line " key = \"increase\";" f)
(write-line " }" f)
(write-line " label = \"Decrease\";" f)
(write-line " value = \"0\";" f)
(write-line " key = \"decrease\";" f)
(write-line " }" f)
(write-line " }" f)
(write-line " label = \"Type\";" f)
(write-line " //is_enabled = false;" f)
(write-line " label = \"Numerals\";" f)
(write-line " key = \"num\";" f)
(write-line " }" f)
(write-line " label = \"Alphabet\";" f)
(write-line " key = \"alpha\";" f)
(write-line " }" f)
(write-line " }" f)
(write-line " " f)
(write-line " label = \"Rate\";" f)
(write-line " label = \"One\";" f)
(write-line " key = \"one\";" f)
(write-line " }" f)
(write-line " label = \"Two\";" f)
(write-line " key = \"two\";" f)
(write-line " }" f)
(write-line " label = \"None\";" f)
(write-line " key = \"none\";" f)
(write-line " }" f)
(write-line " }" f)
(write-line " ok_cancel;" f)
(write-line "}" f)
(close f)
(load_dialog fn)
) ;_ end of defun
(princ)
;|«Visual LISP© Format Options»
(120 2 40 2 T "end of " 80 9 0 0 1 T T nil T)
;*** DO NOT add text below the comment! ***|;
Ho Jorge,
If you would consider using a third-party tool, we have a very elaborate text counter command in our productivity tools, GeoTools for Bricscad. You can add/create/remove text with prefix/suffix, do incremental counting (both numeric and alphabetic), update existing text optionally, apply on block attributes optionally, insert/delete from existing series and much more.
You can want to see all that this command does : http://www.4d-technologies.com/geotools/manual/text_tools.htm#TC
I have not yet taken a look at this routine that you posted here. I will probably do so when I get to my office and see if I can modify it and achieve what you want.
Regards
Rakesh Rao
Blog: http://rakeshrao.typepad.com0 -
thanks Rakesh
I heard about geotools before and looks great all the functions, but my problem is (I forgot to explain this before) I am using the linux version of Bricscad, for this reason my request about lisp routines like this one.
thanks again, I hope somebody can help me with this routine
regards
Hi Jorge,
There is a plan to create GeoTools for Linux on Bricscad but I cannot get myself to sit down and do the exercise of porting it to Linux and to deal with all the issues therein - debugging, resolving Windows dependencies, installation, licensing and so on.
I am sure if I cut out the GT_TC command and run the Lisp on Linux, it will run but the larger picture is what I am trying to fit.
If there are any more of you who would love to see GeoTools on Linux, let me know. The more the number, I might start to do some work in this direction. Nevertheless, it is still on my mind and I hope to have GeoTools-Linux-Bricscad. That would be really good.
Regards
Rakesh Rao
