Dimension horror
When you try to use the Continue dimension, all the dimension lines take a different angle and so with the Baseline. Please HELP ME.Seba.
  • .....do you draw in ortho-mode ?....switch it on
  • Continous and baseline only work if you start with a linear dimension (hor/vert).If you start with aligned dims you will get problems.Baseline still has a bug on vertical dims.
