changing dimstyle
Hi all,
I was wondering if there is an easy and fast way to switch to another dimension style ?
Now I always have to go to the "drawing explorer - dimension styles" and right mouse click on the dimension style I want, choosing "set current".
Can't you just switch your dimstyle it in the same way you can switch to another layer, just choosing in a dropdown list ?
I tried to customize my toolbars but can't find the correct tool/control...
greetz
  • See button in the status bar near snap button.
  • Right click this button.
  • Thanks !
    This will save me some time :-)
  • Please, doesn't  possible as in autocad see -by left click on a dim- see the own type of dim style? With autocad there is a little window on the right of the dimension bar that shows it, without the need to use "property". Forthermore: doesn't possible change the precision of the a single measure shown by right click on?
  • I think you want to use the "dimension styles" button. It can be found in the "settings" menu.
  • Thanks Marcel, I now it and should be better to use the the button in the status bar near snap button but, that I need is by an easy click on one of several dim onto dwg to see the type and/or to change a few property as the precision shown.
