DESCODER: How to access text file in des?
It is possible to combine lsp-files and txt-files into a single des-file. But how can a lsp-file then read from a txt-file in the same des-file?
lsp-file: ReadMyTxt.lsp
(defun ReadMyTxt ( / file line)
(setq file (open "ReadMyTxt.txt" "r"))
(setq line (read-line file))
(close file)
line
txt-file: ReadMyTxt.txt
Info from ReadMyText.txt
  • Dear Roy,
    here it is : (vl-get-resource txtfile)
    <txtfile> is the name of the text file which is included in *.des file ...
    Should work fine ... otherwise, please tell me ...
    Many greetings, Torsten
  • Works perfectly. Thanks you Torsten.
