getOsnapPoints(...) function doesnot gets called when the entity is derived from AcDbPolyline
getOsnapPoints(...) function doesnot gets called when the entity is derived from AcDbPolyline and when snap mode is ON. The same function gets called when entity is derived from AcDbEntity.
Any thoughts??
Can you send the problem as SupportRequest, please ?
So it is logged into our database, and all related devleopers can share ...
If you have a little test code, it would be of great help (in case we could
not reproduce with our internal samples), but it is not mandatory.
Many thanks in advance !0
