autoload vba
How does one set a vba program to load every time Bricscad starts up?
Also I don't seem to be able to search this forum.  Any ideas why the search function doesn't find anything at all, even for words like "the"?
Thanks in advance.
  • As long as you only enter a single search term you should get as many results as there are occurences of the word.  If you want to use multiple terms then you are better off using google with the "site:" parameter set to "www.bricsys.com".  If you only type in "the" and don't get a result then file a support request as this works fine for me (using chrome).
    regards,
