exlpode circle 2 ployline (lines)
Does anyone knows how to explode a circle into linesegments?
See this topic at the Swamp:
Hi Markus,
just an explaination on the lisp routine link.
You can't explode a circle to line segments. You can, however replace the circle with a multi-sided polygon (100 in the case of the lisp routine), and explode that.
thanks for the answer, the lisp wirks fine
