extrim command
hi
I use a lot the command EXTRIM of AUTOCAD, specially to extract some area from a city plan or something like that, using a poliline as limit of the desired area. With Extrim only I do two clicks and ready.
I can not do this with bricscad, if somebody has a lisp routine to do this will be great for me.
thanks a lot
You can try this. It is a work in progress.
(defun c:EET (/ *error* initial_set point1 point2 temp_set touching_set counter1)
(defun *error* (message)
(and message
(not (wcmatch (strcase message) "*BREAK*,*CANCEL*,*QUIT*"))
(princ (strcat "\nError: " message))
(command "._undo" "end")
(defun dxf (1code 1ent) (cdr (assoc 1code 1ent)))
(defun delta (a1 a2 / r1)
(cond
((> a1 (+ a2 pi))
(setq a2 (+ a2 (* 2.0 pi)))
((> a2 (+ a1 pi))
(setq a1 (+ a1 (* 2.0 pi)))
(setq r1 (- a2 a1))
(if (< r1 0.0)
(setq r1 (+ r1 (* 2.0 pi)))
r1
(defun VxGetTangentAtPoint (Obj Pnt / CurPar PntLst TmpPnt)
(setq PntLst (VxGetEndPoints Obj)
CurPar (cond
((equal Pnt (car PntLst) 1E-5)
(vlax-curve-getStartParam Obj)
((equal Pnt (cadr PntLst) 1E-5)
(vlax-curve-getEndParam Obj)
((setq TmpPnt (vlax-curve-getClosestPointTo Obj Pnt))
(if (<= (distance TmpPnt Pnt) 1E-5)
(vlax-curve-getParamAtPoint Obj TmpPnt)
(T nil)
(if CurPar
(angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv Obj CurPar))
(defun VxGetEndPoints (Obj)
(list
(vlax-curve-getStartPoint Obj)
(vlax-curve-getEndPoint Obj)
(defun left_test (ls_object ls_point / temp_point temp_point2)
(setq temp_point (vlax-curve-getClosestPointTo
ls_object
ls_point
(setq normal (- (VxGetTangentAtPoint
ls_object
temp_point
(/ pi 2.0)
(if (< normal 0.0)
(setq normal (+ normal (* pi 2.0)))
(setq delta_angle (delta normal (angle temp_point ls_point)))
(if (or (< delta_angle (/ pi 2.0))
(> delta_angle (* 3.0 (/ pi 2.0)))
(setq side nil)
(setq side T)
side
(defun get_point (gp_point gp_object gp_trimmer_object gp_left /)
(entmake (list (cons 0 "CIRCLE") ; make a circle with radius 0.01
(cons 6 "CONTINUOUS")
(cons 8 "POWER")
(cons 10 gp_point)
(cons 39 0.0)
(cons 40 0.01)
; (cons 60 1)
(cons 62 2)
(cons 210 (list 0.0 0.0 1.0))
(setq bounds (entlast)) ; get the circle
(setq bounds_entity (entget (entlast))) ; get the circle's entity
(setq counter 0)
(setq gp_inters_list (vlax-invoke ; check for intersection object
(vlax-ename->vla-object (dxf -1 bounds_entity))
'IntersectWith
gp_object
acExtendNone
(entdel bounds)
(setq gp_inters_points nil)
(if gp_inters_list ; if there are intersections ...
(progn
(repeat (/ (length gp_inters_list) 3) ; convert the data to points
(setq gp_inters_points (cons (list (car gp_inters_list)
(cadr gp_inters_list)
(caddr gp_inters_list)
gp_inters_points
(setq gp_inters_list (cdddr gp_inters_list))
(setq point1 (car gp_inters_points)) ; there is at least one point
(if (> (length gp_inters_points) 1)
(setq point2 (cadr gp_inters_points)) ; get the second point if there is one ..
(setq point2 nil) ; or set the second point to nil
(if (/= point1 nil) ; left_test will error if the point is nil
(if (= (left_test trimmer_object point1) gp_left) ; point1 same side as trim side?
point1 ; yes, return point1
(progn ; no ...
(if point2 ; is there a point2?
point2 ; yes, return point2
nil ; no, return nil
nil
(defun do_trim (dt_trimmer_object dt_object_ename dt_intersection_list dt_left_side / )
(setq dt_intersection_list_points nil)
(setq dt_object (vlax-ename->vla-object dt_object_ename))
(if dt_intersection_list ; if there are intersections ...
(progn
(repeat (/ (length dt_intersection_list) 3) ; convert the data to points
(setq dt_intersection_list_points (cons (list (car dt_intersection_list)
(cadr dt_intersection_list)
(caddr dt_intersection_list)
(setq dt_intersection_list (cdddr dt_intersection_list))
(foreach memb dt_intersection_list_points
(progn
(setq dt_intersection_point memb)
(setq dt_point3 (get_point dt_intersection_point ; intersection point
dt_object ; object to trim
dt_trimmer_object ; "trim to" object
dt_left_side ; "trim to" side
(if (/= dt_point3 nil)
(progn
(setq dt_trim_list (list (vlax-vla-object->ename dt_object) dt_point3))
(command "trim" (vlax-vla-object->ename dt_trimmer_object) "" dt_trim_list "")
(vl-load-com)
(command "._undo" "begin")
(setq trimmer_selected nil)
(while (= trimmer_selected nil)
(setq trimmer_selected (entsel "\nSelect trimming edge: ")) ; get the "trim to" selection
(setq trimmer_entity (entget (car trimmer_selected))) ; get the "trim to" entity
(if (and (/= (cdr (assoc 0 trimmer_entity)) "LINE") : only accept these types
(/= (cdr (assoc 0 trimmer_entity)) "ARC")
(/= (cdr (assoc 0 trimmer_entity)) "SPLINE")
(/= (cdr (assoc 0 trimmer_entity)) "LWPOLYLINE")
(/= (cdr (assoc 0 trimmer_entity)) "POLYLINE")
(/= (cdr (assoc 0 trimmer_entity)) "CIRCLE")
(/= (cdr (assoc 0 trimmer_entity)) "ELLIPSE")
(setq trimmer_selected nil) ; try again if necessary
(setq trimmer_ename (cdr (assoc -1 trimmer_entity))) ; get the "trim to" ename
(redraw trimmer_ename 3) ; highlight the "trim to" selection
(setq trimmer_object (vlax-ename->vla-object trimmer_ename)) ; get the "trim to" object
(setq side_point (getpoint "\nSelect trimmed side: "))
(setq left_side (left_test trimmer_object side_point))
(vla-getboundingbox trimmer_object 'point1 'point2) ; get the bounding box for the "trim to" selection
(setq point1 (vlax-safearray->list point1) ; get the bounding box points
point2 (vlax-safearray->list point2)
(setq temp_set (ssget "_C" ; get entities in the bounding box into temp_set
(trans (list (car point1) (cadr point2) 0.) 0 1)
(trans (list (car point2) (cadr point1) 0.) 0 1)
(ssdel (car trimmer_selected) temp_set)
(while (> (sslength temp_set) 0) ; while there are entities in temp_set ...
(setq object (vlax-ename->vla-object (ssname temp_set 0))) ; get the first entity
(if (setq intersection_list (vlax-invoke ; check for intersection with the "trim to" entity
trimmer_object
'IntersectWith
object
acExtendNone
(do_trim trimmer_object (ssname temp_set 0) intersection_list left_side)
; trim the crossing entity
(ssdel (ssname temp_set 0) temp_set) ; delete entity from temp_set
(princ)
(defun printss (ss / counter)
(setq counter 0)
(while (< counter (sslength ss))
(print (entget (ssname ss counter)))
(setq counter (1+ counter))
)0 -
hi Martin
very nice routine, works very good with no big plans, but when I used in a plan with a lot of level curves, like a topographic plan this error appears:
Error: Automation Error 80020009; Error accessing [INTERSECTWITH] method. ErrIndex=0
: ._undo
Undo: Mark/Back to mark/BEgin set/End set/Control/Auto/<Number of steps to undo>: end
Cancelyou routine works, but I do not know why appears this error, I hope you continue working in this very nice routine.
regards
With this Google search:
autolisp cookie cutter "Permission to use, copy, modify, and distribute this software"You can find a version of EXTRIM which still has the "friendly" AutoCAD copyright notice:
http://bbs.mjtd.com/thread-28699-1-1.html0 -
The version of EXTRIM at the bbs.mjtd.com site appears to be missing several lines.
hi Roy
thanks for the link, I found a routine but gives the next error:
Cannot find AC_BONUS.LSP
looks like an error for a application from autocad 14, but I could not find a solution.
;;; EXTRIM.LSP - Written by Randy Kintzley
;;; Copyright (C) 1997 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty and
;;; restricted rights notice below appear in all supporting
;;; documentation.
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;GLOBAL INFO.;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;Functions created as result of loading file: extrim.lsp
; ANOTHER_OFFSET
; ETRIM
; GET_FENCE_POINTS
; INTERSECT_CHECK
; TRUNCATE_2_VIEW
;Variables created as result of loading file: extrim.lsp
;Functions created as a result of executing the commands in: extrim.lsp
;Variables created as a result of executing the commands in: extrim.lsp
; BONUS_ALIVE
; BONUS_OLD_ERROR
;Extended-TRIM - cookie-cutter routine
;Select a polyline, line, circle or arc and a side to trim on
(defun c:et ( / dxf na p1 redraw_it) (if (and (not init_bonus_error)
(equal -1 (load "ac_bonus.lsp" -1))
);and
(progn (alert "Error:\n Cannot find AC_BONUS.LSP.")(exit))
);if
(init_bonus_error (list
(list "cmdecho" 0
"highlight" 0
"regenmode" 1
"osmode" 0
"ucsicon" 0
"offsetdist" 0
"attreq" 0
"plinewid" 0
"plinetype" 1
"gridmode" 0
"celtype" "CONTINUOUS"
T ;flag. True means use undo for error clean up.
'(if redraw_it (redraw na 4))
);list
);init_bonus_error ;local function
(defun dxf (a b / ) (cdr (assoc a b)));defun (princ "\nPick a POLYLINE, LINE, CIRCLE, or ARC for cutting edge..")
(setq na (single_select '((-4 . "<OR")
(0 . "CIRCLE")
(0 . "ARC")
(0 . "LINE")
(0 . "LWPOLYLINE")
(-4 . "<AND")
(0 . "POLYLINE")
(-4 . "<NOT")
(-4 . "&")
(70 . 112)
(-4 . "NOT>")
(-4 . "AND>")
(-4 . "OR>")
T
);single_select
);setq
(if na
(progn
;(setq e1 (entget na));;setq
(redraw na 3)
(setq redraw_it T) (setq p1 (getpoint "\nPick the side to trim on:"));setq
(redraw na 4)
(setq redraw_it nil) (if p1 (etrim na p1));if
);progn
);if (restore_old_error)
(princ)
);defun c:extrim ;!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
;Entity-TRIM function
;takes: na - entity name
; a - a point, the side to trim on
;NOTE: This function does not allow for the possible miss of
; non-continuous linetypes.
(defun etrim ( na a / la dxf b d e1 lst lst2 n j k m ss na2 na3 na4
x y z flag flag2 flag3
) ;local function
(defun dxf (a b / ) (cdr (assoc a b)));defun (setq e1 (entget na));setq
(if (or (setq flag (equal (dxf 0 e1) "POLYLINE"))
(setq flag (equal (dxf 0 e1) "LWPOLYLINE"))
(equal (dxf 0 e1) "LINE")
(equal (dxf 0 e1) "CIRCLE")
(equal (dxf 0 e1) "ARC")
);or
(progn
(if (and flag
(equal 8 (logand 8 (dxf 70 e1)))
);and
(setq flag nil)
);if
(setq a (trans a 1 0));setq
(command "_.ucs" "_View")
(setq lst (ep_list na nil) ;;;find extents of selected cutting edge object
lst (maxminpnt lst)
x (- (car (cadr lst)) (car (car lst)))
y (- (cadr (cadr lst)) (cadr (car lst)))
x (* 0.075 x)
y (* 0.075 y)
z (list x y)
x (list (+ (car (cadr lst)) (car z))
(+ (cadr (cadr lst)) (cadr z))
);list
y (list (- (car (car lst)) (car z))
(- (cadr (car lst)) (cadr z))
);list
);setq
(command "_.zoom" "_w" x y)
(entupd na) ;;;update the ent. so it's curves display smoothly (setq lst (ep_list na
(/ (pixel_unit) 2.0)
);setq
(if (or (not flag)
(not (p_isect lst nil))
);or
(progn ;then the object is valid and not a self intersecting polyline.
(if (and flag
(equal (car lst) (last lst) 0.0001)
);and
(setq flag3 T);then the polyline could potentialy need a second offset
);if
(if (setq la (b_layer_locked (getvar "clayer")))
(command "_.layer" "_unl" (getvar "clayer") "")
);if
(command "_.pline")
(setq b nil)
(setq n 0);setq
(repeat (length lst)
(setq d (nth n lst))
(if (not (equal d b 0.0001))
(progn
(command d)
(setq lst2 (append lst2 (list d)));setq
(setq b d);setq
);progn
);if
(setq n (+ n 1))
);repeat
(command "")
(setq na2 (entlast)
ss (ssadd)
ss (ssadd na2 ss)
lst nil
);setq
(ss_visible ss 1)
(setq lst2 (get_fence_points na2 a lst2 flag3 flag));setq
(if la
(command "_.layer" "_lock" (getvar "clayer") "")
);if
(command "_.ucs" "_p")
;Move the ents to force a display update of the ents to avoid viewres problems.
(setvar "highlight" 0)
(if (setq ss (ssget "f" (last lst2)))
(command "_.move" ss "" "0,0,0" "0,0,0")
);if
(if flag
(progn
(if (setq la (b_layer_locked (dxf 8 e1)))
(command "_.layer" "_unl" (dxf 8 e1) "")
);if
(ucs_2_ent (dxf 210 e1))
(command "_.copy" na "" "0,0,0" "0,0,0")
(entdel na)
(setq na3 na
na (entlast)
);setq
(command "_.pedit" na "_w" "0.0" "_x")
(if la (command "_.layer" "_lock" (dxf 8 e1) ""));if
);progn
);if
(command "_.trim" na "")
(setq m (- (length lst2) 1));setq
(setq k 0) ;@rk
(repeat (length lst2)
(setq lst (nth k lst2))
(setq a (trans (car lst) 0 1))
(setq n 1)
(repeat (- (length lst) 1) ;repeat each fence list
(setq b (trans (nth n lst) 0 1))
(if (equal a b 0.0001)
(setq flag2 T)
(setq flag2 nil)
);if
(setq na4 nil);setq
(setq j 0);setq
(while (not flag2) ;repeat each segment of the fence until no new ents are created.
(setq na4 (entlast));setq
(command "_F" a b "")
(if (and (equal na4 (entlast))
(or (not (equal k m))
(> j 0)
);or
);and
(setq flag2 T)
);if
(setq j (+ j 1));setq
);while
(setq a b);setq
(setq n (+ n 1));setq
);repeat
(setq k (+ k 1))
);repeat
(command "")
(if flag
(progn
);if
(entdel na) ;get rid of the copy
(entdel na3);bring back the original
);progn
);if
);progn
(progn
(princ "\nSelf intersecting edges are not acceptable.")
);progn else invalid self intersecting polyline
);if
(command "_.zoom" "_p")
);progn then it's a most likely a valid entity.
);if
);defun etrim ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun another_offset ( pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4 / na ss lst da1 da2) (setq da1 (abs (- a2 a1)));setq
(setq da2 (- (* b (max pl2 pl1))
(/ (* b (abs (- pl2 pl1)))
2.0
);setq
(if (> (abs (- da2 da1))
(* 0.01 (max a1 a2))
(progn (pline (list lst2))
(setq na (entlast)
na2 (entlast)
ss (ssadd)
ss (ssadd na ss)
);setq
(ss_visible ss 1)
(command "_.offset" b na2 a "")
(if (and (not (equal na (entlast)))
(setq lst3 (vtlist (entlast)))
(setq lst3 (intersect_check lst2 lst3 lst4))
);and
(progn
(ss_visible (ssadd (entlast) (ssadd)) 1)
(command "_.area" "_ob" (entlast))
(setq pl2 (getvar "perimeter")
a2 (getvar "area")
);setq
(setq lst (list (vtlist (list (entlast) 0))));setq
(entdel (entlast));then offset was a success so delete the ent after getting it's info
);progn then
(if (not (equal na (entlast))) (entdel (entlast)));if else
);if
(entdel na2)
);progn then let's do that second offset
);if lst
);defun another_offset ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun get_fence_points ( na2 a lst2 flag plflag / a1 a2 pl1 pl2 b c d n
lst lst2 lst3 lst4 na
) (if flag
(progn
(setq lst2 (cdr lst2));setq
(repeat (fix (/ (length lst2) 2))
(setq lst2 (append (cdr lst2) (list (car lst2)));append
);setq
);repeat
(setq lst2 (append lst2 (list (car lst2))));setq
(command "_.area" "_ob" na2)
(setq pl1 (getvar "perimeter")
a1 (getvar "area")
);setq
);progn
);if (setq a (trans a 0 1)
b (* (getvar "viewsize") 0.05);initial offset distance
n 3.0 ;number of offsets
d (/ b (- n 1)) ;delta offset
c (pixel_unit)
lst4 (viewpnts)
);setq (while (> b c)
(setq na (entlast))
(or (not plflag)
);or
);and
(progn
(setq lst3 (lsttrans lst3 1 0))
(if flag
(progn
a2 (getvar "area")
);setq
);progn
);if
(setq lst (append lst (list lst3)));setq
(entdel (entlast)) ;delete the ent after getting it's vertex info
(if flag
(another_offset pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4)
);append
);setq
);if
);progn then offset was a success
);if
(setq b (- b d));setq
);while
(setq na (entlast))
(command "_.offset" c na2 a "")
(or (not plflag)
);or
);and
(progn
(if flag
(progn
a2 (getvar "area")
);setq
);progn
);if
(if flag
(another_offset pl1 pl2 a1 a2 c na2 lst2 a lst3 lst4)
);append
);setq
);if
);progn then
);if
(entdel na2) lst
);defun get_fence_points ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;returns a list of points on screen if the first two lists do not
;contain segments that intersect each other.
(defun intersect_check ( lst lst2 lst3 / x x2 y y2 lst4 flag len len2
a aa b bb c d n j) (setq len (length lst)
len2 (length lst2)
x (car (car lst3))
x2 (car (cadr lst3))
y (cadr (car lst3))
y2 (cadr (cadr lst3))
);setq (setq n 0);setq
(while (and (not flag)
(< (+ n 1) len2)
);and
(setq aa (nth n lst2)
bb (nth (+ n 1) lst2)
a (truncate_2_view aa bb x y x2 y2)
b (truncate_2_view bb aa x y x2 y2)
lst4 (append lst4 (list a))
);setq
(if (or (not (equal a aa))
(not (equal b bb))
);or
(setq lst4 (append lst4 (list b)))
);if
(setq j 0);setq
(< (+ j 1) len)
);and
(setq c (nth j lst)
d (nth (+ j 1) lst)
flag (inters a b c d)
);setq (setq j (+ j 1));setq
);while (setq n (+ n 1));setq
);while
(if (not (equal b (last lst4)))
(setq lst4 (append lst4 (list b)));setq
);if
(if (not flag)
(setq flag lst4)
(setq flag nil)
);if
flag
);defun intersect_check ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun truncate_2_view ( a b x y x2 y2 / int)
(if (and (< (car a) x)
(setq int (inters a b (list x y 0.0) (list x y2 0.0)))
);and
(setq a int)
(if (and (> (car a) x2)
(setq int (inters a b (list x2 y 0.0) (list x2 y2 0.0)))
);and
(setq a int)
);if else
);if
(if (and (< (cadr a) y)
(setq int (inters a b (list x y 0.0) (list x2 y 0.0)))
);and
(setq a int)
(if (and (> (cadr a) y2)
(setq int (inters a b (list x y2 0.0) (list x2 y2 0.0)))
);and
(setq a int)
);if else
);if a
);defun truncate_2_view
(princ "\n \"EXTRIM\" loaded.")
(princ)0 -
Sorry about that: I should have tested the code from the link.
Here's another link:
http://www.theswamp.org/index.php?topic=24646.0;all
This is CookieCutter2 by Joe Burke. You may have to join the Swamp to be able to download the files. Note that there is an updated version in post #23. Please also read post #34: it is a 2D routine so it will not work if your level curves have a z elevation.
I have tested this time ;-) and it works OK for me.0 -
My code was failing when it tried to break an inserted block. Around line 206 change the (setq temp_set ... to this:
Cookie Cutter 2 by Joe Burke is an excellent routine that I recommend, but it only accepts closed entities as trimming entities. I needed a routine that would use a line as the trimmimg entity.(setq temp_set (ssget "_C" ; get entities in the bounding box into temp_set
'((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))
)0 -
Hi Martin
again, thank you very much really, and Roy, thanks to you too, also you routine help me a lot, thanks guys.
Only I need to check if these routines work in bricscad linux that I use in the office.
thanks again
Hi Martin
sorry to bother you again. your routine works great in bricscad windows, but not in bricscad linux, if you could help me making workable this routine in bricscad linux I will appreciate it very much.
This is the error or the routine in bricscad linux V11.
: eet
: ._undo
: ._undo
Undo: Mark/Back to mark/BEgin set/End set/Control/Auto/<Number of steps to undo>: begin
; ----- LISP Error : Call Stack -----
; [0]...C:EET <<--
; ----- Error around expression -----
(VLA-GETBOUNDINGBOX TRIMMER_OBJECT 'POINT1 'POINT2)
Error: no function definition <VLA-GETBOUNDINGBOX> at [EVAL]
: ._undo
Undo: Mark/Back to mark/BEgin set/End set/Control/Auto/<Number of steps to undo>: end0 -
The error message says that VLA-GETBOUNDINGBOX is not implimented in the Linux version of Bricscad that you have. I do not have a Linux computer here to test with.
BTW:
If the segment you want to cut out is rectangular using the fence or crossing option in the trim command can already be a great time-saver.0
