problem with slice in V11.3.5
I'm trying V11.3.5. on Ubuntu 10.04.
I noticed a problem with command "slice". I tried to define the slicing plane through 3 points, but I'm always prompted for only 2 points. Here is the sequence:
: SLICE
Select entities:
Opposite Corner:
Entities in set: 1
Select entities:
Specify first point on slicing plane or Object/Zaxis/View/XY/YZ/ZX/<3points>:
Specify second point on slicing plane:
Specify a point on desired side of the plane or <Both>:
  • @Roberto:
    The 3 points method is the default choice, but does not work. Try it again, but use the right click context menu, so you can explicitly choose to use the 3 point method. It should work. The windows version does the exact same thing. It's just a bug that hasn't been worked out of either platform.
    Cheers.
