Mpolygon
  • Hello,
    MPOLYGON objects are not yet supported in Bricscad. You can bring in a DWG containing MPOLYGON and it will display but you cannot edit it.
    In addition, I think I just found a bug. If you have 1 MPOLYGON in the dwg saved from AutoCAD, it becomes 2 in Bricscad. I will file a SR.
    Regards
    Rakesh Rao
    Blog: http://rakeshrao.typepad.com
