svg format export
Is it possible to export map in svg format ?
If yes, with which version ?
thanks a lot
  • Unfortunately Bricscad is not able to export SVG. Please make them know that you need it, create a ticket for it. I think SVG export is a must on Linux, just as they have WMF export for Windows.
    Until then you have several possibilities, depending on your need and skillset. I hardly doubt this list is exclusive :)
    1. You could write a SVG export plugin in LISP. This is for tech savvy only.
    2. You could write DXF to SVG converter in your favourite language, I'd use python. Or use an existing one: http://sourceforge.net/projects/dxf-svg-convert/
    3. You could print to PDF and open it in Inkscape, then save to SVG.
    4. You could use any commercial DWG2SVG converter.
  • hello, thanks a lot for yours advice. Indeed, it's for a use with inkscape.
    I saw that the 11.3.8-1 version in french is available. Maybe, it will be possible with ?
    In any case I will try with a dxftosvg converter...
    thanks
  • Hi,
    Any news about a version of bricscad for linux with the svg export format ?
    Or where I can found a dwgtosvg converter?
  • Bricscad Linux should be able to export SVG files since the version 11.3.15.
    http://www.bricsys.com/common/releasenotes.jsp?p=B4L&l=en_US
    It's not available in my language, so I can't tell you more about it... ( french translators are so slow )
