attribute info and round up an round down.
i measure buildings with a totalstation, I can get a dxf from the machine who i can import to bricscad.
Now i have 2 questions :
first of all :
i give a codename to a point in the totalstation, that comes into the attribute name field codename.. can I filter someway on this filed ? So I can reduce the points to get a better idea of the drawing.
Second question is something strange....
If i make the drawing by connecting the points I get some unusefull measurements, like 72.12547... I would like to make that line automaticly 72.0000, so it needs to roud up or down automaticly so i've got nice dimensions to work. Is there something that can help me with that ?
Dear Mr. Kong,
If you don't mind using a third party add-on tool for Bricscad, I would suggest you take a look at GeoTools.
With GeoTools productivity pack, you can do all that you asked.
1. Search & Filter attributes (can also replace) :(GeoTools->Blocks & Attributes -> Search and reaplce text/attributes) GT_ZOOMTXT (http://www.4d-technologies.com/geotools/manual/block_tools.htm#ZOOMTXT )
2. GT_ROUNDOFF (GeoTools -> Miscellaneous Tools -> Round off values from points/lines) ( http://www.4d-technologies.com/geotools/manual/miscellaneous_tools.htm#ROUNDOFF
3. GT_TXTROUND (GeoTools -> Text Tools -> RoundOff Numeric Text) ( http://www.4d-technologies.com/geotools/manual/text_tools.htm#TXTROUND )
Let me know if you have more questions.
Regards
Rakesh Rao
Blog: http://rakeshrao.typepad.com0
