errors with cut, copy and paste
Does everyone else have problems with the function cut/copy paste?
I try to cut an object, but I get "error 80, the file already excists", and it does not work to copy object either. Have anyone else experienced this problem ad wish to help me troubleshoot this problem?
Ken, I have never experienced the problem you describe. Can you provide more details?
What are you copying?
How are you copying it?
Which version of the program are you running?
Version 10.1.7 english
It does not matter what I am copying, it can be a simple line. Nor does it matter whether it is a big size dwg or a new small one.
I am just trying to copy a basic line from one point to another using either ctrl+c or using the right click and copy.
The same problem is for the cut function. error 80 occurs, but I can't find any info of this error, except what it says, cannot make a temporary file "the file already excists". I do not know whether it is the machine causing problems or if it is some commands which I accidentally have pressed in Bricscad causing this jam of cut,copy, paste commands. I do not have these problems with other programs, and I just reset my system back to 2 days ago (before I realized this problem) but that did not help either.
Hi Ken,
I do not recall having that error even when I ran v10. I assume you have already checked if there is free space on the file system.
I don't know if the program needs to create a temporary file for a clipboard operation. My guess would have been no but it is only a guess.
It sounds like you have been running Bricscad for a while and are just getting this error? If yes I would suspect a virus or other corruption of the installation.
You should send in a support request because the version of v10 I had at the time was 10.1.11. Support will likely send you a link to download.
Either way I would:
- create a new user profile, and
- prevent customizations from loading
If that does not fix it remove and reinstall Bricscad. Here I would try the latest version of v10.
Hope it helps.
You could try if cleaning up your TEMP system folder helps (this is where temporary files used for copy/paste are stored).
If this does not help, please send in a support request, our analysts will be glad to help.
I have time to time problem with CTRL+C and CTRL+V and CTRL+SHIFT+V. My SR24858.
PASTE and PASTE AS BLOCK insert diffent things - like separate clipboard.
Ie. first I make copy (CTRL+C) and copy "number 1", paste (PASTE and PASTE AS BLOCK work OK), work, work, make CTRL+C copy "number 2".
And when use PASTE (CTRL+V) it insert "number 2" and PASTE AS BLOCK (CTRL+SHIFT+V) it insert "number 1".
