moving objects on screen - does not show their trace
when I pick an object and move it around the screen - the trace is unseen. also, even when I try to create an object (e.g circle) it will remain transperant until I pick a point - and then it shows me the finished circle, but the trace is unseen.  I have a new screen, can this be the problem ?
  • Sounds like the behaviour when Dragmode is set to Off. Mine is set to Auto.
  • mine was set on auto too, when forced ON still problem remains
  • I don't generally have the problem, but I do have one recent file of about 2.5Mb containing a large clipped block which only shows its border when moving or copying. Another smaller block in the file doesn't visibly drag very well, but creating entities rubber bands properly.
    I did not create the file.
    Perhaps if the monitor refresh rate was slower it would be worse, but mine only has one choice - 60 Hz.
