Importing option settings
Hi there,
The option settings in Bricscad came be exported to a CSV file. I am wondering if there is a way to import the settings on another machine. I would like to be able to set up multiple CAD stations with similar settings.
Thank you in advance for your help.
Phillip
Use the Profile Manager to export the profile. It will be saved as a .arg Windows Registry file.
See discussion here http://www.bricscad.com/common/support/forumthread.jsp?id=12565 about changing the exported profile so it can be imported to other users.
Hope it helps...
Oh yeah... user profile manager can be found in the Tools menu of a running Bricscad or in the Windows Start menu Bricsys | Bricscad... program group.
