printing problem with raster images after upgrade Bricscad to v11.3.12
Hello This problem started after update Bricscad from V10 to V11.I have a problem with printing the drawings containing raster images (TIF, b&w, 2-bits). When printing (layout or model) I get printout without raster (blank pages with vector graphics only).I used option raster transparency = YES to drawing. Correct print raster image is possible, when I turn off transparency. In v10 print with both option transparency (yes and no) was correct. What is wrong ?The same problem I have with print to pdf (Bullzip, etc.). I must set image transparency to NO. If another I have e blank pages (but in v10 was the same).I use Brisccad 11.3.12, printer HP designjet 111, Windows 7-64.RegardsDarek Kaszewski
  • I had a similar problem. The raster image would print but the resolution would be very low causing very poor image quality. Try updating to v11.3.14, that fixed my printing problems.
