Rendering guidance
I am looking for input from people who have experience in rendering and setting up for best looks.
When I render an object with straight edges, the shadow cast has very jagged edges, which doesn't look realistic to me. Does anyone know if this is intentional or if there are settings to adjust the way shadows are displayed?
I am using Platinum version 11.3.12 but I think the result was the same on older versions of Platinum and Pro.
Use the File option on the Render dialog, the enter the desired resolution in the Width and Height field to get a high resulution rendered image.
