pdf export
Hello how can i set the page dimension and the orientation of the page when i export to a pdf
Thanks
You should have a PDF EXPORT OPTIONS in the File menu (or not, if you upgraded from an older version). These options are in the Settings dialog box, under Program Options>File>PDF Export.
You can change the page size by checking Enable papersize override and filling the desired values in the corresponding "width/height" fields in PDF Export Options. There is no Orientation option, but if you need landscape mode, for example, you can try switching the width and height values. Please feel free to file a support request in case a feature is missing but you find it useful.
