delete a x-ref in the x-ref manager
is it possible to remove a attached x-ref totaly from the x-ref manager so that it is not listed anymore?
Yes, for me it is possible. If you are seeing something odd you might try running AUDIT, close and save then open the draing file again to see if that remedies your problem. There might also be something in the file causeing the XREF to reload... i.e. a block defined with an XREF in it or some other nested XREF.
Can you provide any more details? What do you do and what does the manager show? Which version are you using?
