Opening a bunch of files
Is Bricscad able to open a group of selected files? When i try to do so by selecting them, then pressing 'enter' or click RMB then select 'open' Bcad fails to open all of them, and then acts weird: sometimes it only open one file, sometimes it opens some of them in different console but not all , and always showing a message box "error: invalid file type" for the rest of files it doesn't open...
  • I have just had the same experiences. It has mostly worked fine in the past, although it seems like you can overload it. If you try ctrl alt del after shutting down, you might find multiple instances of Bcad still running. One or two of your files might open as you end the instances. To me, it seems to work well when I haven't been working intensively on one or more files.
