bricscad as ole in ms office?
Hi, is it somehow possible to insert a Bricscad-drawing as an ole-object in ms office? (Without having Acad installed.) Thx.
  • There used to be a free Autodesk utility called DWF Writer which allowed importing CAD files into MS Word documents.  I have not used it with BricsCad but had put Pro/ENGINEER files into an Office document and the results were impressive - it allowed manipulation (spinning, zooming) of the model from within the Word document.  At the time, I considered it a poor man's 3D PDF creator.  It was a plug-in that allowed DWF creation directly from the Pro/E software.
    Last that I knew, DWF Writer did not work with Windows Vista and later systems.
