Issue with 11.4.2 Windows Installer?
I attempted to update my installation with the 11.4.2 installer available from the Bricsys homepage. After completion of the download, I executed the executable and received a warning that the installer had encountered an error with the following info:
AppName: bricscad-v11.4.2-1-en_us.exe AppVer: 12.0.0.58855 ModName: bricscad-v11.4.2-1-en_us.exe
ModVer: 12.0.0.58855 Offset: 0001ec42
Anybody else having this issue?
Is the downloaded file's MD5 hash correct? The downloads are large and, even though there are checksums built into the TCP/IP envelope, occasionally a bad packet will slip through.
If you need a MD5 app, Slavasoft has free <a href="http://www.slavasoft.com/fsum/">command line</a> and <a href="http://www.slavasoft.com/hashcalc/index.htm">GUI</a> hash utilities. I always check and, FWIW, the 11.4.2-1 installer ran to completion correctly here.
