Attribute editor's value no longer starts with selected text
When attributes are edited in 11.3.12, the value is initially selected (highlighted in blue, so when you press a key the text is replaced).  In 11.4.2, the value is not selected, so if you want to replace it, you have to first select it.
It's a small thing, I know - but I really liked the way it used to work!  Is there a setting for this?
Thanks!
  • I am having the same problem + more with the attribute editor in 11.4.1. If you leave the attribute value in without first deleting it than when you type in your new value it goes in the main box in front of the of your original value with a box dividing the two. As it is not shown this way in your value box (for entry) you cannot now erase it and the original value appears on your plan as a suffix to the new value. The workaround is then to edit the value through the property dialogue box - block editing. The attribute editor will not allow you to edit it.
  • Indeed I noticed that too, if you're used to type your value immediately, it's a little bit annoying.
    Deleting the value however takes only 0,5 second by just typing "shift+end" + "delete"
