RTEXT and Diesel scripting in the drawing?
I noticed that if you insert RTEXT using AutoCAD, and use Diesel code within it, then open the drawing with BricsCAD, the RTEXT shows up properly, and the Diesel code works just fine...
Now, how can I insert RTEXT and/or Diesel script into the drawing from BricsCAD?
