Convert Data of Block Attribute in text multilines
Good morning,
I liked to know how it was possible to convert data contained in a block Attribute, in texts multilines, always in my drawings (no export of text file). I try to search, I do not find ......
Thank you
  • This is my lisp for doing that, which I use a lot. It might need polish to work for you and it's probably no example of good programming, but there it is.
    (DEFUN c:CAT (/ oldl oldlp ss n p1 a b c p q p2 p3 p4 r s)
    (SETVAR "CMDECHO" 0)
    (SETQ OM (GETVAR "OSMODE"))
    (SETVAR "OSMODE" 0)
    (if (/= 0 (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))))
    (progn
    (princ "\nTextsize must be 0 ")(terpri))
    (progn
    (setq oldl (getvar "clayer"))
    (COMMAND "LAYER" "M" "DEFPOINTS" "")
    (SETQ OLDP (GETVAR "LUPREC"))
    (SETVAR "LUPREC" 0)
    (setq ss (ssget "x" '((0 . "INSERT")(66 . 1))) n 0 p1 nil p1 (getpoint "\nStart Point: "))
    (while (/= n (sslength ss))
    (setq a (ssname ss n) b (entnext a) c (entnext (entnext a))
    d (entnext (entnext (entnext a)))
    p (cdr (assoc 2 (entget b)))
    q (cdr (assoc 1 (entget b)))
    p2 (polar p1 0 (* (getvar "textsize") 12))
    p3 (polar p1 0 (* (getvar "textsize") 24))
    p4 (polar p1 0 (* (getvar "textsize") 36)))
    (if (= "ATTRIB" (cdr (assoc 0 (entget b))))
    (progn
    (setq p (cdr (assoc 2 (entget a))))
    (command "text" p1 "" "" p)))
    (progn
    (setq q (cdr (assoc 1 (entget b))))
    (command "text" p2 "" "" q)))
    (if (= "ATTRIB" (cdr (assoc 0 (entget c))))
    (progn
    (setq r (cdr (assoc 1 (entget c))))
    (command "text" p3 "" "" r)))
    (if (= "ATTRIB" (cdr (assoc 0 (entget d))))
    (progn
    (setq s (cdr (assoc 1 (entget d))))
    (command "text" p4 "" "" s)))
    (setq n (1+ n) p1 (polar p1 (* 1.5 pi)(* (getvar "LTSCALE") 0.4)))
    (SETVAR "LUPREC" OLDP)
    (command "layer" "S" oldl "")
    (SETVAR "OSMODE" OM)
