Dragging Problem
Have a problem similar to Yuval W. When I grab an object to move it. the image appears in a different location the mouse indicates. When creating a line, object, etc. the items cannot be seen until a endpoint is selected. I have set the enity dragging setting to whenever possible and the dragmode is set to Auto. Any thoughts?
Sounds like a video driver issue - I had similar problems some time ago (but on Linux), until Bricsys introduced a variable (GLSWAPMODE) to give some control over the GL engine - may be worth checking out on widows, too.
comment before me is correct: one time I used a program that changed my windows apperance from normal win7 to something earlier and it fixed everything: the dragging and the snapping issues.
