Points
I am used to working with surveying kit which outputs a symbol at the surveyed point, but I have just been given a CAD file which has just a 'point' at each point. Apart from actually inserting a symbol at eack point, and there are several hundred of them, is there any way of inserting a symbol at every 'point' in a file. And not the route of changing the point display parameters, because that will / might have implications when the drawing is used further down the line. Thanks in advance.
    Hi Ralph,
    If you want to know of a solution using a third-party tool, here is a solution using GeoTools:
    If you have many points (or text or circles) in your drawing and want to replace them with blocks, here is an easy way in Bricscad using GeoTools: Convert Points/Text/Circles to Blocks/Shapes: http://goo.gl/9NDZl
    Regards
    Rakesh Rao
    http://rakeshrao.typepad.com
  • You could try this:
    (defun c:update ( / selset counter obj ent ent_point)
    (setq flt '((-4 . "<OR") (0 . "POINT") (-4 . "OR>")))
    (if (setq selset (ssget flt))
    (progn
    (setq counter 0)
    (while (< counter (sslength selset))
    (setq obj (ssname selset counter))
    (setq ent (entget obj))
    (setq ent_point (cdr (assoc 10 ent)))
    (command "_insert" "E_RECFLOOR" ent_point "1.0" "1.0" "0.0")
    (entdel obj)
    (setq counter (1+ counter))
    Change E_RECFLOOR to the block name for the symbol you want to insert.  Change both "1.0" to whatever scale factor you need.
  • Thanks, will give it a try.
