Leaders with no text annotation
I am wanting to just add lines/ splines with an arrow on one end between points but with no text attached.
I can 'blunder' my way through this but its just that - 'blunder'.
Is there a simple way to add Leaders between entities that doesn't involve text please.
regards
  • You just go LE(der)<ret> point, point,... <ret><ret> N(one)<ret>.
    I have a lisp which starts at the normal second point, then the arrow end, then adds one optional tail without adding text, if you want it.
  • The following command macro creates a 2-segment leader with no text: _DIMLEADER;\\\;;n
    Create a new tool in the CUSTOMIZE dialog, then assign the tool to a keyboard shortcut or add it to a custom toolbar.
  • thanks for the answers.
    Louis that works well and the customised toolbar is very good. and I wouldn't mind your lisp routine John thanks.
    I can play around with both then.
    LE(der)<ret> point, point,... <ret><ret> N(one)<ret>.  I was doing that in a roundabvout way in my messing about.  Now I understand it, my blundering has ended. Thanks
  • (Defun c:mylead (/ a b c)
    (SETVAR "ORTHOMODE" 0)
    (setq a (getpoint "\nPick Leader End Point: ")
    b (getpoint a "\nPick Leader Start Point: "))
    (SETVAR "ORTHOMODE" 1)
    (IF (NOT (setq c (getpoint a)))(SETQ C A))
    (command "leader" b a c "" "" "n")
  • thanks John - works very nicely. Created an alias and voila!
    Is there a simple way to set the leader to a spline before the process starts?
    Sorry , should have asked all the questions first.
    regards
  • The command asks for a first and second point before giving options. I think you would have to add in variations you want, predicting what will be asked. Like a script. I modify leaders to  splined later if I need them, but since I usually don't I keep it simple. Rather than interrupt for variations I would make a separate lisp or change that one to make splines.
  • Here is a routine I use all the time, called "qldr" - similar to AutoCad's quickleader command.  I suppose you could add to the last command line to make the straight line leader a spline.
    (defun C:qldr ( / pt ptlst)
     (setq ptlst (list (setq pt(getpoint "\nStart of leader.."))))
     (command "._pline" pt)
     (while pt (setq pt (getpoint pt "\nNext leader point.."))
       (if pt (setq ptlst (append ptlst (list pt))))
       (command pt)
     (command "_.erase" "L" "")
     (command "_.LEADER" ptlst "" "" "_n")
  • Steven, thanks for the leader code.  I am attempting to do the modifications to make it do spline leaders without, text and another with text.  However, my LISP expereience is around 20 years old, so I am more than a bit rusty. I have tried a zillion variations on that last line, and I can't get it to do Mtext.It is as though it is ignoring the "Mtext" part of my command.
    Any ideas what I am doing wrong?
    Joe Dunfee
    Here is my LISP, followed by the results copied from the command line history;
    ;Creates a spline leader with text.
    ;slt is for spline leader.
    (defun C:slt ( / pt ptlst)
       (command pt)
     (command "_.LEADER" ptlst "format" "spline" "exit" "" "" "Mtext")
    : slt
    Start of leader..
    : ._pline
    ENTER to use last point/Follow/<Start of polyline>:
    Arc/Distance/Follow/Halfwidth/Width/<Next point>:
    Next leader point..
    Arc/Distance/Follow/Halfwidth/Width/Undo/<Next point>:
    Next leader point..
    : _.erase
    Select entities to delete: L
    Entities in set: 1
    : _.LEADER
    Start of leader:
    Next point:
    To point:  Format/Undo/<Annotation>: format
    Arrow/None/SPline/STraight/<Exit>: spline
    Arrow/None/SPline/STraight/<Exit>: exit
    First line of annotation text/<options>:
    Dimension text options:  Block/Copy/None/Tolerance/<Mtext>: Mtext
    First line of annotation text/<options>: nil
  • Try this:
    (command pt)
    ; (command "_.LEADER" ptlst "format" "spline" "exit" "" "" "Mtext")
    (command "_.LEADER" ptlst "F" "SP" "E" "" "" "" "" "")
  • @ Joe Dunfee:
    If you want a spline leader with text you could also consider a macro:
    http://forum.bricsys.com/discussion/16005
    Two lisp solutions using your and Steven's code as a starting point:
    ; Creates a spline leader with text.
    ; slt is for spline leader.
    (defun c:slt ( / pt ptlst)
    (setvar 'cmdecho 0)
    (setq ptlst (list (setq pt (getpoint "\nStart of leader: "))))
    (while pt (setq pt (getpoint pt "\nNext point: "))
    (command pt)
    (command "_.erase" "_last" "")
    (command "_.leader" ptlst "_format" "_spline" "_exit" "_annotation")
    (princ "\nFirst line of annotation text: ")
    (setvar 'cmdecho 1)
    (while (> (getvar 'cmdactive) 0)
    (command pause)
    (princ)
    (defun c:slt2 ( / pt ptlst)
    (setvar 'cmdecho 0)
    (if
    (and
    (setq ptlst (list pt))
    (progn
    (command "_.leader" ptlst "_annotation" "" "_none")
    (while (setq pt (getpoint pt "\nNext point: "))
    (command "_.leader" ptlst "_format" "_spline" "_exit" "_annotation" "" "_none")
    (setvar 'cmdecho 1)
    (command pause)
    (princ)
    (princ)
  • Thanks Roy for reminding us of that simple one-liner to make the spline and allow for text.  I had gotten lost in the forest and only saw trees.
    Joe Dunfee
