image file import and create outline of object
Is there a build in function or add on porgramme in bricscad that allow me to import image file( jpg,bmp or png) and creates an outline of the object. example --> [img]http://www.cadkas.com/paperausenlinien.png[/img]
Yoyo,
Here are two suggestions / solutions:
Solution 1: If you use our GeoTools add-on, there is a command called GT_BOUNDENT under the Draw Tools menu which will draw a bounding box around any set of selected objects, including raster image objects.
Solution 2: The complete source of this small tool is reproduced here.
Let me know how it works.
Regards
Rakesh Rao
http://rakeshrao.typepad.com;; | ---------------------------------------------------------------------------
;; | C:BoundEnt
;; | Function : Draw a closed rectangle polyline at the bounding box of the
;; | selected object(s).
;; | Argument :
;; | Return : None
;; | Updated : February 16, 2007
;; | Author : Rakesh Rao (www.coordsys.com)
;; | ---------------------------------------------------------------------------(defun c:BoundEnt ( / ent ename ss Lst LL UR OS )
(setvar "CMDECHO" 0)
(vl-load-com)(princ "\nSelect object(s) to enclose with bounding box:")
(setq OS (getvar "OSMODE"))
(setvar "OSMODE" 0)(setq ss (ssget))
(if ss
(progn
(setq
Lst (SS_BoundingBox ss)
LL (nth 0 Lst)
UR (nth 1 Lst)
(command "._Pline" LL (list (car LL) (cadr UR) 0.0) UR (list (car UR) (cadr LL) 0.0) "_Close")
(princ "\nA closed polyline rectangle was drawn covering the extent of the selected objects.")
(setvar "OSMODE" OS)
(prin1)
;; | SS_BoundingBox
;; | Function : Returns the selection set bounding box coordinates in the form
;; | of a list of Lower Left and Upper Right points.
;; | Arguments: 'ss' - Selection Set to examine
;; | Returns : 'Lst' - is a list of LL and UR
;; | Updated : June 10, 2005
;; | e-mail : rakesh.rao@4d-technologies.com
;; | Web : www.4d-technologies.com
;; | -----------------------------------------------------------------------------(defun SS_BoundingBox ( ss / ssl cnt llX llY urX urY ename cnt Lst LL UR _llX _llY _urX _urY )
(setq
ssl (sslength ss)
cnt 0
llX 1E20
llY 1E20
urX -1E20
urY -1E20
(repeat ssl
(setq
ename (ssname ss cnt)
cnt (1+ cnt)
Lst (GE_GetObjectBoundingBox ename)
LL (nth 0 Lst)
_llX (car LL)
_llY (cadr LL)
UR (nth 1 Lst)
_urX (car UR)
_urY (cadr UR)
)(if (< _llX llX)
(setq llX _llX)
)(if (< _llY llY)
(setq llY _llY)
)(if (> _urX urX)
(setq urX _urX)
)(if (> _urY urY)
(setq urY _urY)
(list (list llX llY 0.0) (list urX urY 0.0))
;; | GE_GetObjectBoundingBox
;; | Function : Returns the object bounding box coordinates in the form of a
;; | list of Lower Left and Upper Right points.
;; | Arguments: 'ename' - Object to examine
;; | Updated : April 28, 2000
;; | Comments : VL-function, works with AutoCAD 2000 only
;; | ----------------------------------------------------------------------------(defun GE_GetObjectBoundingBox(ename / ll ur vname )
(setq vname (vlax-ename->vla-object ename))
(vla-GetBoundingBox vname 'll 'ur)
(setq
ll (vlax-safearray->list ll)
ur (vlax-safearray->list ur)
(vlax-release-object vname)
(list ll ur)
)(princ "\nType 'BoundEnt' to start.")
(prin1)0 -
thanks rakeshfor both the solutions, as for solution 2 how do i input this script into bricscad? do i need to cut n paste into a txt file or?
Hello,
Copy the entire code into a text editor, save the file with a .LSP extension and you can load the Lisp into Bricscd using the appload command. You can then use the BOUNDENT command on the command line.
Regards
Rakesh Rao
www.4d-technologies.com0 -
just curious, were you able to get something to work?
daniel, im able to load the new function into briscad but unsure of how to use the new tools.
Hi Yoyo,
Whilst useful I don't think Rakesh's routine will provide you the result you seek. The Boundent routine I believe will simply place a bounding box around the extents of your image, which will be the same as the imageframe.
From your image example (http://www.cadkas.com/paperausenlinien.png) it looks like you want a routine that traces around the boundary of shapes within the image, which in your case would result in the word "Paper" being traced. This is quite a different excercise (raster to vector conversion).
There are a couple of applications available from the applications area that may fit your requirements. Take a look at Insyde Raster or Kalibronek under the applications general section http://www.bricscad.com/common/applications/applicationlist.jsp?estore.ApplicationCategory=8
If you only require to do this for a few images you could always just attach the image and trace around it yourself.
Just to add to Jason's comment, if you only have a few images to process, I have a routine that will import an image in as points, you could then connect the points with lines or polylines
