New Version Question
When the new version comes out, what new additions will it have? And what will it have fixed?Also will it insert blocks with the "Z" Scale equal to the "X" & "Y" instead of having unequally scaled blocks. If you insert a block where you specify the scale and insertion point on the screen then it will not scale the "Z" equal to what you set the "X" & "Y". This is a real problem for my office. It worked fine in version 25 but it changed in 27.
  • When is the new version scheduled for release via the download?What features will be fixed? In addition to the z scaling, what about vertical dimensions above the line? What about the snaps? Lips? Overall stability with x-refs and the ability to snap to xrefs? Also, memory leaks? What about tools for audit and recover?ICAD has been adequate, but now with the way drawings from ACAD 2000i and ACAD 2002 being recieved, seem like there are more and more crashes.
