Save as dialog to narrow to see file formats
I just installed 11.3.16 version of BC for Lin and when I chose "save as", the bar where you chose the file format to save to is to narrow to se what file format is selected (only about 3 characters). I am not sure if this is related to bricscad or GTK , but since all file format versions start with Aut... this is a big issue.
Anyone who has the same problem?
I am on Arch Linux x86_64 with 32-bit comp libraries installed to run BricsCAD.
BR, Mikael
Functions fine on debian 32bit with 'mist' gtk theme - did you check wether this is consistent with different themes and gtk-font settings?
Thanks for the reply Knut,
I tested on my laptop instead with the same setup and there the problem does not occur. Hm very strange. On the laptop I initially installed BrCAD 10 and have upgraded this installation a couple of times. That is the only difference I can think of.
I guess I will have to test with mist GTK engine as well to see if the problem goes away.
