LISP routine to work-around the deferred perpendicular snap issue?
There are a couple of posts earlier in the forum (one from me) about the new feature that gives priority to "deferred perpendicular" snap when selecting the first point of a new line. Until (we hope) there is some option built into Bricscad to disable this, would it be possible to devise a LISP routine that could be used to do the following:
- Turn on whatever running snaps the user wants, but disable perpendicular snap (this could be hard-coded by the user).
- Start the line (select first point)
- Turn on perpendicular snap again, along with the others that the user wants (how to do this in middle of the LINE command I don't know)
- Finish drawing the line
Any guidance would be much appreciated! Thanks.
Try this:
; Uncomment the next two lines to replace the line command:
; (command "_.undefine" "line")
; (defun c:Line () (c:AltLine))
(terpri)
(defun c:AltLine ( / pt)
(setq pt (getpoint "\nUsing AltLine \nStart of line: "))
(command "_.line" "_none" pt)
(while (> (getvar "cmdactive") 0)
(command pause)
(princ)
)0 -
Many thanks -- works great!
