Autosave pre A2k?
Does the autosave function save as IC98?My autosave keeps telling me that "this pre a2k does not support some entities in the drawing"
You're right. This is a bug. It is added to our change request database.Currently autosave saves as DWG version 14 format.FYI:If you save as DWG then the first 6 carracters of the resulting file indicates the DWG version acording to this list.AC1004 Rel.9 AC1006 Rel.10 AC1009 Rel.11/12AC1012 Rel.13 AC1014 Rel.14 AC1015 Rel. 2000 - 2002Jeroen TheunsBricsnet QA
