V12.Net API: How to get and entity by its handle?
Hello all,
I've  started to play around with the .NET API in V12 (using C#) and run into following challenge:
How do I get reference to an entity if I know its handle?
Actually I look for a specific Paperspace Viewport (by its handle)
Do I have to cycle the Paperspace block (using a BlockTableRecordEnumerator) until I find an entity with the correct handle or is there a quicker way?
Huge amount to (re) discover after 10 years playing with COM!
T.I.A.
Arno van Eeuwen
  • On with the .NET quest...
     Document doc = AcAp.Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor editor = doc.Editor;  try {   long ln = Convert.ToInt64(rxConfig.Handle, 16);   Handle hn = new Handle(ln);   ObjectId id = db.GetObjectId(false, hn, 0);             using (Transaction tr = db.TransactionManager.StartTransaction())   {      Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
          Some more code here....    }
    Now in my case the entity I try to acces using the above code lays on a locked layer.
    The GetObject fails....
    So: how to make sure to unlock the layer of an entity when I only know it's ID?
    TIA
  • Transaction::GetObject has an overload, forceOpenOnLockedLayer.... the signature should be
    public virtual DBObject GetObject(ObjectId id, OpenMode mode, bool openErased, bool forceOpenOnLockedLayer);
    give that a whirl and see what happens
    Cheers!
  • Why are you not in the pub celebrating your birthday? ;-)
    Ah, you brought you own from Belgium!
    Thanks Dan, another mistery solved. As I said, loads to discover.....
  • I'm headed to the pub now : )
