add more control to a toolbar
in the control dialog i now possible add : color, layer, linetype, lineweight
is there a way to add more control ?
for example : dim style control, text style control, Viewport Scale Control . . . . .
Isn't all what you want, but, in right bottom corner of BC, at first position are coordinates (x,y,z), next one is textstyle and next is dimstyle. On this two you can make right click and select what you want.
