Add Block using .NET Programming
Hi!,
I would like to know how will I add block/insert entities programmatically using .NET.
Sample code will be very helpful.
Thank you very much
if you have a look at this link, http://www.theswamp.org/index.php?topic=31859.0 , you can find many examples of how to do this. the only difference is you may have to swap a few name spaces
Cheers!
Daniel
Daniel,
Thank you for your fast response. I will try the codes.
Thanks again.
