Temporary Graphic lines using .NET programming
Hi!
I would like to know how will I programmatically draw a temporary graphic lines in Edit Window using .NET programming.
Sample code will be very much helpful.
Thank you.
you can p/invoke sds_grdraw example
[assembly: CommandClass(typeof(BcadMgdTest.Commands))]namespace BcadMgdTest{ public class Commands{ //needs using System.Runtime.InteropServices;[DllImport("Bricscad.exe", CallingConvention = CallingConvention.Cdecl)] static internal extern int sds_grdraw(double[] startPoint, double[] endPoint, int color, int hightlight); //needs using Teigha.Runtime;[CommandMethod("doit")] public static void doit(){ sds_grdraw(new double[] { 0.0, 0.0, 0.0 }, new double[] { 100.0, 100.0, 0.0 }, 6, 0);}}}
static internal extern int sds_grdraw(double[] startPoint, double[] endPoint, int color, int hightlight);//needs using Teigha.Runtime;
}0 -
Daniel,
Thank you the codes. it worked! Though my requirements is in VB.NET I was able to convert it.
Thanks again.
<DllImport(
"Bricscad.exe", CallingConvention:=CallingConvention.Cdecl)> _
Private Shared Sub sds_grdraw(ByVal startPoint() As Double, ByVal endPoint() As Double, ByVal color As Integer, ByVal highlight As Integer)
End Sub
