x solids hardware error V12
in Other
Trying out V12 and can't insert a bolt or nut. Always get a revolve error but washers and wingnuts work fine. Anyone encounter this? All in all this is an impressive release. Would like to see a "extrude to" command for when you need a solid to connect with another without going all the way through.
Hex nut & Hex bolt inserted with no problem on my trial version.
Works fine here (current V12.1.4). Possibly an unexpected value in a left-over setting from an earlier installation?
Just got a reply from support and they said x-hardware will not work correctly when elevation is set at anything but zero. A fix is on the way.
