Isolate Layer
V12 Platinum Version 12.1.4 id 32852 revision 24087.
The Isolate Layer command now locks all layers other than the layer of the selected entiity,and does not turn any layers off it did as in V10.
When you use this command in "brand new" installation, you must at first use settings for this command:
_layiso
Current setting: Hide layers, Viewports=Vpfreeze
Select entities on the layer(s) to be isolated or [Settings]:Here type S and enter.
Then select: on "Enter setting for layers not isolated [Off/Lock] <Off>:" and etc...
Thanks Juraj.
That has solved my problem.
