MtmdEdit v3.3 with BC V12
'Morning,
With BC V12 I am not able to load the prg to modify easly (almost as Autocad 2000LT) MtmdEdit lisp.
The BC reports after the start and running the on_start.lsp: "* (arxload) : can not LOAD file <C:\Program Files\Bricsys\Bricscad V11\Support\MtmdEdit_BricsCAD\MtmdEdit.11.brx>"
The path is correct, however I tried to copy the files into \Support under Bricscad V12\... but it does not work.
The support does not answer me yet.
Meantime I came back to V11, otherwise I miss Docstab also...
Why BC does not acclude the basic but modern solutions ( as an example: the dim editor and 2d array looks like the oldest of Autocad Dos version r10 and Windows r12 ) instead to promote only sofisticated functions.
Note: I appreciate the news functions very, sure, but how much time to ripersonalize with the basic useful functions at every new version and revision!
