Deferred perpendicular and other v12 questions
We just made the switch from v9 to v12, and have noticed a few things we cannot figure out how to turn off. For example:
Deferred perpendicular snap....this takes precedence over all other snaps and is annoying.
when esnaps are on snaps activate (ie, mid points are highlighted, etc) even if no commands are given. I only want the snap icons to show up when a command is given.
fyi, I have snaptracking off, polar tracking off, dynamic input off
Hovering the pointer over any object, line, etc. highlights that item even if no commands are active. I only want the item highlighted if I select it.
Any help getting these behavioral peeves corrected would be greatly appreciate.
for highlighting at hovering : set SELECTIONPREVIEW as 2 (not 1 or 3);
also, enter "effect" in search field of settings dialog :-)0 -
The deferred perp and tangent snap priority was changed with v12.1.3, are you using an older release?
I don't have enaps unless there is a command active but I don't know of a setting to change that... Is this always happening for you?
where is the bricscad v12.1.4?0
The snap problem is also (still) fixed in the current version (12.1.13).0
