RefEdit fails with error msg
in Other
I get this error message when trying to edit an xref: "REFEDIT failed. Reason: Entity is excluded from long transaction"
Can anyone shed any light on this (what it means, why I get the message, how to fix)?
Thanks in advance!
Works ok on my machine, you might try running an audit to see if your drawing has something weird in it. else, send in a support request along with your drawing.
Audit worked, thanks.
