Default XL Shortcut Not Calling XLINE As Expected
So I tried to draw an xline using XL for the command, I type XL at the propmpt and nothing happens, the command line returns nothing...
Command: XL <Return>
Command:
If I type the following:
Command: xline <Return>
Infinite line: Bisect/Horizontal/Vertical/Angle/Parallel/<Point along Line>:
The command works as expected. I have checked my PGP file and XL, *XLINE is referenced, note that this is also an issue in autocad 2009, I am running BC V12.1.5 Any ideas?
XL works fine for me (same BC version).
Since you have the same issue with AC it is perhaps some lisp application with a function like this:(defun c:XL () (princ))
Whoops:
(defun c:xl () (command ".-xref" "r" "*") (princ))
I made a typo that should be c:xr, but it explains why I can't reload xrefs or why I can't draw xlines in acad or bcad, thanks for getting me to think about it haha...
