Viewport can access properties
Hi, - I have a VP that when I select it says there are two objects in the selection (see image), but I know there are not, and of course I cant edit the VP.
This VP has been clipped, and unclipped VPs in the same drawing don't have this problem. Drawing is a simple, 2D 470kb file.
Doe anyone have a clue what's going on?
cheers, nigel
Running Bricscad 11.2.7 on Windows 7
  • Nigel: a clipped viewport is a pair of entities. There is a viewport and the clipping boundary. They are automatically grouped together and attempting to select the viewport will select the pair of entities. Once you select the pair the properties panel will show 2 entities are selected. Use the drop-down at the top to choose to see properties for viewport entities.
  • Thanks Greg - I was going round and round trying to sort that one.
